cancel
Find Qualified
Local Contractors
Select Service:
Enter Zip:
community forums
Insulation 2 - Preparation
comments
  • Currently2.97/5 Stars
  • 1
  • 2
  • 3
  • 4
  • 5
out of 941 votes
Intro - Prep - Wall Preparation - Cellulose - Repair
What You Will Need
Time. Time depends on the type of job being done. Allow yourself 3 to 4 person hours per 100 square feet when installing fiberglass batts and a vapor barrier in the attic. Allow yourself 4 to 6 person hours per 100 square feet when installing furring, insulation, and vapor barrier in your basement.
Tools. Most of the tools required for the installation of insulation are found in the home toolbox. Others can be rented reasonably from your local home center.
  • Dust mask
  • Goggles
  • Gloves
  • Hammer
  • Pencil and paper
  • Hole saw
  • Trouble light
  • Drill
  • Extension cord
  • Spackling knife
  • String
  • Circular saw
  • Steel tape measure
  • Ramset (rental)
  • Circular saw
  • Level
  • Utility knife
  • Caulking gun
  • Staple gun and heavy-duty staples (An alternative tool would be an compressor with a stapling attachment.)
  • Blowing machine (rental, if you choose air to blow in your insulation)
Materials. As with any home project the materials you will need depend on the type of insulation used and the extent of work being done. Your list will include many of the following:
  • 2 x 4 boards
  • Tar paper
  • 16 penny nails
  • Sheet metal flashing
  • Flexi-vent material
  • Drain pipe
  • Duct tape
  • Gravel
  • Fiberglass insulation
  • Tape
  • Vapor barrier (6 mi. visquine)
  • Plastic
  • Cellulose
  • Caulk
  • Spackling
  • Waterproofing sealant
  • Long, straight board
  • Closable vents
  • Rigid foam panels (regular or closed Drain files cell)
  • Pipes
  • 2" x 2" furring strips
  • Sump pump
  • Adhesive
  • Soffit ventilation plugs
  • Shim material
  • Sheet metal, louvered and screened vent
  • Continuous ridge vent
  • 2" extruded foam panels
  • Wind turbine
  • Construction adhesive (for exterior use and foam panels)
Permits and Codes
Codes for insulation requirements will vary in different parts of the country. A permit may be required in some areas if the work being done exceeds $100 in cost Check with your local building inspector. Codes also will indicate required R-factors.
Design
Choose the most effective insulation for a particular situation. I offer widely accepted suggestions but the climate, existing insulation, and design of your home will affect your decision.
Most Common Mistakes
Perhaps the most fundamental and often overlooked mistake do-it-yourselfers make when insulating is neglecting to find out the most efficient R-value for their area and insulating accordingly. Other common mistakes are listed below.
  1. Not providing for good air circulation between the roof and the insulation.
  2. Installing fiberglass batting with the paper side (vapor barrier) facing toward the outside instead of toward the heated area.
  3. Omitting a vapor barrier, which prevents accumulation of moisture between the batting and the underside of the roof or wall.
  4. Puncturing the vapor barrier unnecessarily, or neglecting to puncture the vapor barrier of the top batt when installing two layers.
  5. Distorting, compressing, or squeezing the fiberglass batt insulation out of shape.
  6. Using paper-faced batting against a heat source like a chimney, a heating duct, etc.
  7. Neglecting to get into all of the small spaces and corners with the insulation.
  8. Covering eaves vents with insulation, thereby cutting off ventilation.
  9. Making unnecessary trips up and down the attic stairs during installation. Assemble all tools and equipment in your work area prior to beginning the job.
  10. Not using closed-cell (waterproof), rigid foam insulation panels on below grade installations
© 2006 DoItYourself.com
member comments
articles we like
Personality of Scorpio
Scorpio, the Scorpion - October 23 to November 21... read more
DIY Party Favor---Think inside the box!
I love to entertain, however, finding unique party favors can be a bit of a... read more
Low Cost Life Insurance? It's Online
Low Cost Life Insurance? It's OnlineUnless you're a carefree, 20-something single with no debt and no property, chances are you've... read more
sponsored articles of the day
diy centers
