cancel
Find Qualified
Local Contractors
Select Service:
Enter Zip:
community forums
Drain Cleaner and Opener Information
comments
  • Currently3.00/5 Stars
  • 1
  • 2
  • 3
  • 4
  • 5
out of 1525 votes
Clogged Drain Prevention. To avoid clogging drains, use a drain strainer to trap food particles and hair; collect grease in cans rather than pouring it down the drain; pour a kettle of boiling water down the drain weekly to melt fat that may be building up in the drain; or weekly put some vinegar and baking soda down your drain to break down fat and keep your drain smelling fresh.
Plunger. A time-honored drain opener is the plunger. This inexpensive tool will usually break up the clog and allow it to float away. It may take more than a few plunges to unclog the drain. DO NOT USE THIS METHOD AFTER ANY COMMERCIAL DRAIN OPENER HAS BEEN USED OR IS STILL PRESENT IN THE STANDING WATER.
For grease buildup, dissolve 1 lb washing soda in 3 gal boiling water and pour down drain. To avoid burns from boiling water, hold water container close to drain and pour slowly and directly into drain. For heavy grease buildup, use a commercial drain opener. Exercise extreme caution when using and follow label instructions exactly. (Commercial drain openers can also be used to clear hair buildup from bathroom drains.)
Baking Soda and Vinegar. Pour 1/2 cup baking soda down the drain. Add 1/2 cup white vinegar and cover the drain if possible. Let set for a few minutes, then pour a kettle of boiling water down the drain to flush it. The combination of baking soda and vinegar can break down fatty acids into soap and glycerin, allowing the clog to wash down the drain. DO NOT USE THIS METHOD AFTER ANY COMMERCIAL DRAIN OPENER HAS BEEN USED OR IS STILL PRESENT IN THE STANDING WATER.
Salt and Baking Soda. Pour 1/2 cup salt and 1/2 cup baking soda down the drain. Follow with 6 cups boiling water. Let sit overnight and then flush with water. The hot water should help dissolve the clog and the baking soda and salt serve as an abrasive to break through the clog.
Mechanical Snake (and Garden Hose). A flexible metal snake can be purchased or rented. It is threaded down the clogged drain and manually pushes the clog away. If used in conjunction with a running garden hose, it can even clear a blockage in the main drain to the street. First crank the snake and feed it into the pipe. Next withdraw the snake and flush the pipe by inserting a garden hose with the water turned on full. With some luck, it may save you the expense of a plumber.
This article has been contributed in part by Michigan State University Extension
member comments
articles we like
Do It Yourself Gutter Repair Tips
Advice and tips for cleaning and repairing your home's gutters... read more
Repair a Leaky Faucet
How to Repair a Valve... read more
Savor Summer Days with Seafood DelightsSavor Summer Days with Seafood Delights
(ARA) - Athens Mini Fillo Shells with seafood sides make a great combination for picnics... read more
sponsored articles of the day
diy centers
