cancel
Find Qualified
Local Contractors
Select Service:
Enter Zip:
community forums
Install a Bathtub Surround, Part 2
comments
  • Currently2.99/5 Stars
  • 1
  • 2
  • 3
  • 4
  • 5
out of 591 votes
By Murray Anderson
< Back to Part 1: Choosing the Surround and Prep
Installing the Tub Surround
1. Your first job is to establish a vertical reference line you can count on. Use a carpenter's level to draw a plumb line, running up from the outside corners of your bathtub.
2. The corner pieces are the first pieces of the tub surround to be installed. First dry fit each one, and if your walls aren't square, adjust the fit by sanding the edges (or trimming, if the walls are really out of square).
3. The panels are often held in place by both adhesive tape applied by the manufacturer, and extra adhesive you apply. Spread a bead of the recommended adhesive around the perimeter of the panel, about an inch in from the tape. Also run extras beads of adhesive across the back of the panel and around any built-ins (i.e., soap dish).
4. Remove the paper from the adhesive tape and set the first corner panel in place. Put one side in position and then apply pressure across the panel to the other side. Finally run your hands over the entire panel, pressing firmly to make sure the glue on the backside adheres to the wall. Install the second corner panel the same way.
5. Once the corners are installed, measure the distance between them, determine the center point and mark it on the tub. Now measure the center panel from the kit to find its center point and mark that point on the panel itself.
6. Apply adhesive to the back of the center panel and remove the paper backing from the adhesive tape. Set the center panel in place by aligning the two centerlines. Press the lower part of the panel against the wall and slowly work your way up to the top, pressing the panel against the wall. Then, run your hands across the entire panel surface, pushing it against the wall.
7. The first side/end panel (the one opposite the plumbing fixtures) will be attached in the same manner as the center panel, except the edge of the panel will be aligned with the vertical reference line you established earlier.
8. You'll need to cut holes for the plumbing fixtures before installing the final end panel. Measure carefully from your vertical line to the center of the various fixtures, as well as from the bottom of the panel to the fixtures. Measure twice, then mark the locations on the panel. You might want to use a piece of cardboard as a trial template because you can't make a mistake when cutting holes for your fixtures.
9. Use a 1" spade bit to cut the holes for the spout. Cutting the larger hole for the faucet will likely be a two step process. Drill a starter hole and then use a Saber saw to cut it to size.
10. Once the holes are cut, apply adhesive, remove the paper backing from the tape and install the panel. Put the panel over the faucet and spout opening first, attach the bottom first, then work your way up to the top.
Waterproofing
Even though the panels overlap and are designed to prevent water from getting in between them, you will need to ensure they're watertight. Use latex mildew resistant caulking all around the bottom edge of the bathtub surround (where it meets the tub), along the seams between the panels and all along the top edge as well (where the tub surround meets the walls).
Reinstall your fixtures, wait a day for the adhesive to set up, and you can start enjoying your beautiful new tub surround.
Murray Anderson is an experienced freelance writer with articles published in both the United States and Canada. He has written on a wide range of topics, but specializes in home maintenance and how to's.
© 2006 Doityourself.com
member comments
articles we like
Cool Weather Plants for Container Gardens
A guide to selecting containers and planting a winter container garden, with a list of... read more
How to Drywall Attics - Safety and Preparation
How to Drywall Attics - Safety and PreparationThis attic section shows you how to drywall when refinishing your attic... read more
Tips for Talking with Your Boss About Tuition Assistance
According to the Society for Human Resources Management 2003 Benefits Survey, 79 percent of employers... read more
sponsored articles of the day
diy centers
